H motor ready to put back together
Dave Z
10-16-2001 18:51:02
Any advice guys? H has a brand new head and i'm wondering if I should use any type of sealant or just the gasket? Rods and pistons are in and I wanna get her back up before winter here in minnesota hits. Any other advice or Tricks On what to do during assy would sure be appreciated.Its a 46
Theman
10-17-2001 05:18:11
 Re: H motor ready to put back together in reply to Dave Z, 10-16-2001 18:51:02
Look on the gasket. Mine said "Sealant Required" right on the gasket. One other tip: Re-torque, re-torque, and then...re-torque. The gasket crushes and the studs relax a bit. It has been 2 months since I put the head on my H and last Sunday I was able to turn the nuts almost a quarter of a turn to bring them back to spec. Unfortunately, you have to remove the rocker arm assembly to check them. It may be a bit messy but it beats a leaky gasket.
F-Dean
10-16-2001 19:01:04
Dave, I use "Gun Grease" on my new head gaskets. It allows them to move if necessary. Also makes it easier to take head off again if necessary. I tighten the head bolts to 75% of torque in a circular pattern starting with the middle bolt in the head. Then 90% of torque in the same pattern and finally 100% in the same pattern. This allows any creep or other minute movements to happen in an orderly manner.
F-Dean
10-16-2001 19:01:23
