Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR
Andy Martin
10-09-2001 07:05:54
Serial number plate is on the right side of the left seat support, under the seat.
Look at thte links at left to determine the age from the serial number. It will be from the late '40's to the early '50's for a Super A.
LOUIS
10-09-2001 08:04:02
 Re: Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to Andy Martin, 10-09-2001 07:05:54
THANK YOU VERY MUCH. THE NUMBER SEEMS TO START WITH FAA 169902
IF YOU KNOW THE AGE I'D APPRECIATE IT. DO YOU KNOW THE SIZE OF MOTOR?
THANK YOU LOUIS
ALABAMA
10-09-2001 09:06:33
 Re: Re: Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to LOUIS, 10-09-2001 08:04:02
I noticed your serial numbers don't match for a Super A (links to left). I can't recall but the you should be able to tell the year from the letter code. Some one else with better references should be able to look it up. It may be a 1947 A that some one modified and put a Super A Sticker on. As far as the tire size goes, I'd have to check when I get home.
ALABAMA
10-09-2001 09:06:06
