IH 300u power steering conversion
c. tolbert
03-04-1999 13:11:51
I own an 300 utility (manual steering) that is in need of steering box rebuilding or replacing.What would be involved in a power steering conversion?Does anyone make a rebuild kit for my steering box?Can I use the steering box from any other IHC/Farmall tractors?Any help would be appreciated.
Robert Hooker
03-05-1999 20:10:20
 Re: IH 300u power steering conversion in reply to c. tolbert, 03-04-1999 13:11:51
I have a row crop 300 and I'd like to install power steering on it too. If you find out how to do it please pass along any info to m
Kevin
08-30-2001 17:09:41
 Re: Re: IH 300u power steering conversion in reply to Robert Hooker, 03-05-1999 20:10:20
I have a tractor without power steering as well.
It has hydraulics. I could connect a hydraulic cylinder to the steering mechanics and connect to hydraulic lines. But not sure what switches or valves are tripped when you steer to the left or to the right to make the cylinder work. Is there a special cyclinder with all the switching or valve operation inclusive? Have either of you had any luck with finding a power steering kit or connection process?
Thanks,
Kevin
