Compression on 450
Serviceman
09-14-2001 17:18:04
I am putting a lp head on a 450 gas and high altitude pistons to raise compression.Should I over size rod bearings or would this be too much compression and be too hard on the engine.I know this is a hard question and I appreciate your input thanks
shannon
09-14-2001 18:27:06
 Re: compression on 450 in reply to Serviceman, 09-14-2001 17:18:04
over sized rod bearings will do nothing to your compression. the only reason you would need oversized rod bearings is if you grind your crank to remove gouges, correct concentricity problems or clearence problems. the lp head and high compression pistions should be fine if you retard the timing and set your mixture accuratly. (detonaton)
shannon
09-14-2001 18:25:51
gene b
09-14-2001 18:20:42
oversizing the rod bngs will not raise compression
Dale13
09-16-2001 05:16:37
 Re: Re: compression on 450 in reply to gene b, 09-14-2001 18:20:42
Unless you grind them on a offset.
