Company Logo Shop Now
Re: Farmall A Steering Problems
Haas
09-13-2001 17:40:03
Check all the tie rods and the steering arm that is attached to the shaft that comes out of the bottom of the steering gear for play. If any of that is loose, especially the attachment of the arm to the steering gear shaft, tighten it up. However, I think your problem is likely in the steering gear. Check to see that the big plug on the front of the steering gear is tight. It has a large hex on it to apply a wrench. In fact, you really need to take that plug out (drain the oil out of the steering gear first) and investigate. Once you have the plug out, you can turn the steering wheel and screw the worm gear out far enough to check the thrust bearing that is on the end of the shaft just inside the plug you took out. It's held on with a castle nut that has a cotter pin through it. I'm betting that the bearing is worn out and has a lot of play. It costs less than $10 for a new bearing. If it's not fixed by this, then you are into taking the steering box off and a complete rebuild.
Haas one more thing
09-13-2001 17:44:56
 Re: Re: Farmall A Steering Problems in reply to Haas, 09-13-2001 17:40:03
Also, the plug in the front of the steering gear must clamp down on the outer race of the thrust bearing to hold it solidly in the steering box and the bearing inner race must be clamped tightly on the steering worm shaft. Sometimes a washer has to be put under the castle nut to get the bearing tight on the shaft. Make sure the washer does not interfer with the movement of the bearing balls and outer race.
Today's Featured Article - The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959. ... [Read Article]
Latest Ad: Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
