Re: decal removal
Author |
Red Dave
09-13-2001 09:39:30
I've done it several times myself and it works just fine for me. But then, my heat gun gets hot enough to bring up the paint too if you aren't careful. In fact it's made to use for paint removal. Did you use a heat gun, or a hair dryer? Some hair dryers might not deliver enough heat.
brianh
09-13-2001 11:05:55
Re: Re: decal removal in reply to Red Dave, 09-13-2001 09:39:30
I used a 1200W Master heat gun, and that thing gets hot enough to burn you pretty bad if you're not careful. I can't see you getting the metal hot enough to separate the adhesive with a hot air heat gun from the front side. The decal I was removing was only about five years old, though, so it had modern adhesive. I was changing it because gas had leaked out around the gas cap due to a bad gasket and had leached out the decals. Maybe old decals with aged adhesive will come off OK with the heat gun method. ?????
Red Dave
09-13-2001 11:29:33
Re: Re: Re: decal removal in reply to brianh, 09-13-2001 11:05:55
I've done it with newer and older decals and it seemed like the older they were the tougher the adhesive was underneath. I don't know why it doesn't work for you. I haven't tried to take one off of a gas tank though. Could the gas be carrying away your heat? Scary thought! I'm not sure I would put much heat on a gas tank. Maybe you should go to an autobody supply and ask for decal remover. I've heard of it, but I haven't used it so I don't know who makes it or how it is used.
JLC
09-13-2001 18:02:19
Re: Re: Re: Re: decal removal in reply to Red Dave, 09-13-2001 11:29:33
It's called aircraft paint stripper and is sold in most auto parts stores. I know that John Deere sells something like this and I would suspect that a CaseIH dealer does too.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
