Re: New magneto
Jim Becker
09-12-2001 07:00:40
You probably need to change the flange out for one that will hold the magneto upright, or you will not be able to get the timing in range. I don't think you can just turn the current one. You will need to remove the impulse coupling, which requires a puller and LOT of care to not break the coupling. Replacement couplings are expensive.
