Removing Steering Shaft from '41 Model B Farmall
Robert C. Opiel
09-07-2001 21:09:27
I am fixing up a 1941 Farmall Model B. I would like to disconnect the steering wheel shaft from the u-joint near the steering gearbox. The u-joint appears to have a key-way and also could be a roll-pin driven thru the u-joint coupling. Does anybody know if this is a tapered pin? Some illustrations show a bolted connection here, but this is not. I was wondering if it might be a button head rivet, maybe you have to grind off the head to drive the pin out??? Any help?? Thanks..
Robert
Dave BN
09-08-2001 02:16:18
 Re: Removing Steering Shaft from '41 Model B Farmall in reply to Robert C. Opiela, 09-07-2001 21:09:27
Mine was a soft pin which I was able to drive out with a punch. Dave.
