Company Logo Shop Now
PTO 3788 to 3588 540/1000
kidd1954
03-15-2009 17:09:35
I would like to trade pto output shafts.I have a 3588 with 1000 pto only, Ifound a 3788 that caught fire and is in a scrap yard that has 540/1000. Is it as easy as just switching the 1000 for the 540/1000 shaft.
pete 23
03-15-2009 20:03:17
 Re: PTO 3788 to 3588 540/1000 in reply to kidd1954, 03-15-2009 17:09:35
Well, that depends. The 3788 did not come with dual pto so some one may have taken care of any internal shaft size changes couplings already . One other thing, there are two different dual pto units, early ones have adjustable pressure engagement valve stem that is pulled up for engage with spring loaded brakes when shut off so shaft will not turn with or without engine running. Later one has hydraulic locked engage with valve spool pushed down in to unit, hydraulic shaft brake that is applied when engine is running and pto shut off but shaft is free to turn when engine is not running. Either unit will fit and work but they have opposite operating lever linkage so you need correct linkage for your unit and correct size and length of internal shaft and couplings. .
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
