1066 Won't stay in reverse
Author |
Mitch Sisson
09-05-2001 11:27:25
1066 IH - manual clutch, 8 speed, no t/a. Made a loud "pop" the first time it happened and started to growl. I had it under a heavy load in reverse. Now it just seems to slip out gently. When this happens, I have to pull (or sometimes push) the shift lever to get back into reverse. I took the top of the range transmission and the spring on the tension arms was missing. I replaced the spring and put it all back together, but it did not fix my problem. My shifter works better, but it still will not stay in reverse. I would appreciate any help or advice on this subject. Thanks, Mitch Sisson - Bellefontaine, MS
R Rahmier
09-05-2001 19:11:04
Re: 1066 Won't stay in reverse in reply to Mitch Sisson, 09-05-2001 11:27:25
I have the same problem with mine I have to hold the shifter in a certain place for it to back up I posted this problem and some good people said I had play in my reverse idler shaft they said you can split the tractor just 8 inches to work on it.I havent done it yet chicken I guess. they also said to take the inspection plate off the side. check the archives type in 1066 transmission you will probably see my post good luck, rich
the tractor vet
09-05-2001 20:42:05
Re: Re: 1066 Won't stay in reverse in reply to R Rahmier, 09-05-2001 19:11:04
You can fix the problem most times with out splitting the tractor, pull the side plate off behind the step and see if the rev. shift fork is broken or there is to much play in the internal linkage , also make sure that you check all the linkage from the shift levers all the way down > Just by replacing the headed pins will make a big differance in free travel. When you remove the side plate you will lose about a gal of High Tran. you can put a coupel of 6 inch blocks under the left tires and you should not lose more then a quart, i think most of the trouble is in the shift fork.
Mitch Sisson
09-05-2001 22:35:55
Re: Re: Re: 1066 Won't stay in reverse in reply to the tractor vet, 09-05-2001 20:42:05
Thanks for the tips. After replacing the missing spring under the range cover, I test drove it before I put the sheet metal back on. I was watching the reverse linkage (several times)when reverse faded out, and could not detect any movement. A broken fork makes sence and would explain the loud "pop" the first time I had this problem. Can the fork be replaced through the inspection plate or will I have to separate the tractor?
the tractor vet
09-06-2001 06:27:57
Re: Re: Re: Re: 1066 Won't stay in reverse in reply to Mitch Sisson, 09-05-2001 22:35:55
Yep while your in there make sure that all is well and replace what is needed. But sometimes you find more then you want and it is required to go a lot feather then you want to get it fixed and spend a lot more then you planed.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
