454/2400A Int.
Author |
Marv
09-04-2001 19:02:01
Can anyone tell me how you count the terms on the distributor cap. The distributor turns counterclockwise. I think I know where term one is. Does it count 1,2,3,4 in order or does it skip around. The firng order stamped on the engine is 1,3,4,2. The tractor runs but not as well as I think it should. If the distributor counts in order Cyl 1 is connected to term 1, cyl. 2 is connected to term 4, cyl. 3 is connected to term 3 and cyl. 4 is connected to term 2. This would have cyls. 2 and 3 reversed, however when I reverse them the tractor will not start. Is it possible that someone could have the timing so far out of normal that the tractor would run with these cyls. reversed. Help Thanks Marv
Haas
09-05-2001 05:15:48
Re: 454/2400A Int. in reply to Marv, 09-04-2001 19:02:01
You count cylinders around the distributor cap 1,3,4,2. Same as the firing order. Normally, the No. on cylinder on the cap is the top one farthest from the engine block. This could change though if someone has messed with the distributor drive parts. Get the No. 1 cylinder at top dead center of the compression stroke. Then what ever position the distributor rotor points to is where you should hook the No. 1 spark plug wire. Then hook in firing order sequence (1,3,4,2) according to the distributor rotation.
Marv
09-06-2001 05:02:44
Re: Re: 454/2400A Int. in reply to Haas, 09-05-2001 05:15:48
Haas Thanks for the information, let me sure I understand the count on the cap. When I am sure of 1 and count countrclock wise 3 would be the second term, 4 would be the third and 2 would be the fourth. This would indicate that this tractor has been running with 3 cylinders in correctly connected. Thanks again Marv
Haas
09-09-2001 17:55:46
Re: Re: Re: 454/2400A Int. in reply to Marv, 09-06-2001 05:02:44
Yes, what you said is correct.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
