Order Farmall Cub Parts Online
184 CUB LOWBOY (1981)
BILL R
09-04-2001 07:44:24
THIS TRACTOR GOES TROUGH A COIL ABOUT EVERY OTHER TIME WE CUT 5 ACRES OF GRASS. I HAVE CHANGED PLUGS, WIRES, POINTS, CONDENSERS. WHAT CAUSES THIS COIL TO KEEP GOING BAD?
Kendall
09-06-2001 15:00:32
 Re: 184 CUB LOWBOY (1981) in reply to BILL R, 09-04-2001 07:44:24
Do you have a ballast resistor in line with the 12V going to your coil? If its not there, the coil will overheat.
BILL R
09-13-2001 08:41:57
 Re: Re: 184 CUB LOWBOY (1981) in reply to Kendall, 09-06-2001 15:00:32
HEY KENDALL, WERE DID YOU GO?
I AM RE POSTING MY QUESTION FROM 9/11/2001.
YES I HAVE A RESISTOR THAT MOUNTS DIRECTLY ON TO THE ALTERNATOR. HOWEVER ALL THE COILS I HAVE USED ("NAPA" IC14, "STANDARD MOTOR PRODUCTS" UC15 AND "WELLS" LU800) SAY RIGHT ON THE COIL BODY "USE WITHOUT EXTERNAL RESISTOR". ALL OF THESE MANUFACTURES, SAY THAT THESE COILS ARE THE ONES, THEIR CATOLOG CALLS FOR ON A 184 CUB LOWBOY, 12v SYSTEM. COULD THE FACT THAT I HAVE A INLINE RESISTOR WITH A COIL THAT DOES NOT REQUIRE ONE, BE THE PROBLEM WITH THESE COILS HEATING UP AND GOING BAD?
BILL R
09-11-2001 09:49:26
YES I HAVE A RESISTOR THAT THAT MOUNTS DIRECTLY ON THE ALTERNATOR. HOWEVER ALL THE COILS I HAVE USED (NAPA IC14, STANDARD MOTOR PRODUCTS UC15 AND WELLS LU800) SAY RIGHT ON THE COIL BODY "USE WITHOUT EXTERNAL RESISTOR. ALL THESE MANUFACTURES SAY THAT THESE COILS ARE THE ONES THEIR CATOLOG SAYS ARE FOR A 184 CUB LOWBOY, 12v SYSTEM. COULD THE FACT THAT I HAVE A INLINE RESISTOR WITH A COIL THAT DOES NOT REQUIRE ONE BE THE PROBLEM?
Mike K
09-05-2001 20:39:36
Go to Auto Zone and get a Wells LU800 coil. Sounds like you're using external ballast coils,the above coil is a non-ballast type which is what you need..... Mike
BILL R
09-13-2001 08:27:52
 Re: Re: 184 CUB LOWBOY (1981) in reply to Mike K, 09-05-2001 20:39:36
HEY MIKE, WERE DID YOU GO?
I AM RE POSTING MY Re: Re: From 9/10/2001.
THE COIL I AM USING IA A "NAPA" IC14 WHICH CROSS REFERENCES WITH THE "WELLS" LU800. IT SAYS RIGHT ON THE UNIT "USE WITHOUT EXTERNAL RESISTOR". IS THIS WHAT YOU ARE REFERING TO AS A "BALAST"?
BILL R.
09-10-2001 10:59:13
IN REPLY TO MIKE K.,
THE COIL I'AM USING IS A "NAPA" IC14 WHICH CROSS REFERENCES WITH THE WELLS LU800. IT SAYS RIGHT ON THE UNIT "USE WITHOUT EXTERNAL RESISTOR". IS THIS WHAT YOUR REFERING TO AS A "BALLAST"?
Jon D
09-04-2001 13:16:19
That probably has a 12 volt system. Are you useing one for a 6 volt system?
BILL R
09-05-2001 08:26:30
 Re: Re: 184 CUB LOWBOY (1981) in reply to Jon D, 09-04-2001 13:16:19
IN REPLY TO JON D, THE SYSTEM IS 12 VOLT AND THE COILS I KEEP GOING THROUGH ARE ALSO 12 VOLT COILS.
THE TRACTOR WILL BEGIN TO MISS AND EVENTUALLY DIE.
AFTER IT COOLS DOWN (THE COIL GETS REAL HOT)YOU CAN USALLY RE-START IT, BUT IT MISS FIRES BADLY. OTHER TIMES IT WILL NOT START AT ALL AND I JUST GO TO THE PARTS STORE AND BUY A NEW $20.00 COIL.
Jon D
09-05-2001 13:31:28
 Re: Re: Re: 184 CUB LOWBOY (1981) in reply to BILL R, 09-05-2001 08:26:30
I'm not shure, but you may have some other electrical problems.
