Farmall M
Dave
08-30-2001 07:09:39
Several days ago I wrote on this post about aquiring a M with the engine already disassembled. The connecting rods are offset of course, and a gentleman told me to put the numbers stamped in the rod toward the cam side. Is this the numbers that tell what cylinder each piston and rod goes in, or a casting number. Can someone explain so a dummy like me can finish rebuilding and put it back together? Thanks.
Dan
08-30-2001 07:35:02
 Re: Farmall M in reply to Dave, 08-30-2001 07:09:39
the number he is referring to is the one that indicates which cylinder each rod goes in, a stamped number on a flat plate. that number goes toward the cam or distributor side of the engine. hopefully someone left the cap with the rod it went with.
The Red
08-30-2001 07:14:05
Dave sit down on the floor facing the engine from the carburetor side. You should be looking at the open end of the rods and bolt on the caps from this side. You will be facing the rod caps to try to make my self clearer.
