H sputtering when you open throttle
Kurt
08-26-2001 18:01:21
Help guys....
I open the throttle up and she starts a sputtering i choke it a little and it comes out of it. Then soon as the choke is off it sputters again...clogged screen possibly or other options.
help me out guys.
thanks Kurt
Anyone going to Billie Creek?
shan
08-27-2001 14:18:45
 Re: H sputtering when you open throttle in reply to Kurt, 08-26-2001 18:01:21
My H does that every now and then mostly on a ditch bank or rough ground I found that I had some rust moving around the tank and it would plug the hole above the shut off picked some out with a magnet and seems to help...shan
Tom W
08-27-2001 04:58:41
Kurt. I had a problem with our H, It would run along fine, then start to sputter and quit. After a minute it would start right up. Checked everything, Gas tank, fuel line, carburetor, nothing worked. One day when it was about to quit, I reached up and took the gas cap off the tank. It started running fine. Turned out that the vent hole in the gas cap was cloged. Opened it up and it hasn't quit since. Tom
FARMALL ED
08-26-2001 19:53:48
YOU MAY FIX IT BY ADJUSTING LIK RED SAID. I HAD THIS PROBLEM AWHILE BACK ON ONE OF MINE I REMOVED THE CARBURATER AND SPLIT IT AND BLEW OUT EVERY PLACE I COULD FIND WITH COMPRESSED AIR PUT IT BACK ON AND THE TRACTOR RUNS GREAT NOW.ED
The Red
08-26-2001 18:37:19
Open up your high speed mixture screw about 1/2 turn. That is the angled one on the bottom of carburetor bowl. Turn counterclockwise to open up.
