Mylar or vinyl ?
J-Philippe Bour
08-24-2001 06:49:32
What is the difference between mylar decals and vinyl decals ? Which one is the best ?
Haas
08-24-2001 18:44:46
 Re: Mylar or vinyl ? in reply to J-Philippe Bourget, 08-24-2001 06:49:32
The vinyl decals that are the individual letters on a paper backing that is removed leaving just the letters are OK. The clear vinyl sheet decals, you should avoid because they tend to stretch when you apply them. If you use the clear sheet decals, get the Mylar. They won't stretch.
Rich
08-24-2001 17:36:09
We, just last evening, put vinyl decals on my WD-9. Yes, they are individual letters and numbers but we did NOT apply them individually. They are all in place on a thin paper that you peel of the front of them after they are in place. Very easy, very quick, no water.
While I have had less experience with the mylar I have to vote for the vinyl. In my opinion they are closer to original because they are individual letters and numbers. They don't look like decals, they look like lettering. But they are more expensive.
Bigdog
08-24-2001 08:21:27
Mylar is a DuPont trademark for a polymer film they produce. It is a very tough, durable, transparent film with very little stretch or shrinkage & does not tear easily. Vinyl will stretch some before tearing so it might fit curved surfaces better. Either should be good for decals.
Bigdog
Farmer Bob
08-24-2001 08:17:20
JPB, My understanding is that the mylar decals are the clear backing (with the printing superimposed upon the mylar). You just peel off the protective paper on the back and place on the unit.
The vinyl decals are individual letters/numbers that you remove one by one and place where you want them. I would assume these take much longer to apply with extra labor/patience involved.
I have never used the vinyl ones as I've always been pleased with the mylar style and think they are a closer match to the original.//FB
