Electrical problems with a farmall cub.
Author |
Eric
08-21-2001 19:09:53
We have a 1950 Farmall cub with a magneto ignition, and a 6 volt system. We cannot figure out how to kill the engine once the engine is running. The magneto has a wire sticking out of it, coming right from the points inside. We have tried conecting that wire to one end of a switch, a ground wire to the other end of the switch, but the engine starts and runs without the switch. The only way to stop the engine is to choke the carburator. Any help would be appreciated.
Farmer Bob
08-21-2001 21:37:19
Re: electrical problems with a farmall cub. in reply to Eric, 08-21-2001 19:09:53
Eric, After using Bill's recommendation below, look at your "kill" switch and see how many contacts it has. The mag switch should only have one contact on it with the wire connected to it and running to the hookup point on the mag as you described. Someone may have slipped in a "two contact" switch meant for a distributer system. Also make sure that the switch is well grounded against metal and not all rusted up or corroded.//FB
Bill Smith
08-21-2001 19:58:37
You said that you hooked up wire from magnito to switch and then hooked up ground to the other side of switch and the switch wouldn't kill the engine. Try jumping the wire straight to a ground bypassing the switch. If it kills the engine then you need a new switch. If the switch quit working, someone probably disconnected it and maybe had a temparary fix on it that is no longer there. Otherwise you are working with a wrong wire or something.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Single front wheel assembly for 18-27 hart par
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
