Farmall 504 brakes
David Cary
08-19-2001 00:14:19
Is there any modifications for the Farmall 504 brake systems? We had new pads put in about 4 years ago and now the left side is nearly gone and the right side just barely works. The tractor is used on a hobby farm, less than 100 hours per year and no abusive use of the brakes. A neighbor ground an extended grove in the pressure plate on a SM-TA that helped. Is this the same type of brakes on the 504?
Michael Soldan
08-19-2001 19:07:29
 Re: Farmall 504 brakes in reply to David Cary, 08-19-2001 00:14:19
Dave it sounds as if the brakes were set up too tight and wore prematurely. Tractor brakes should last for years on a hobby farm or any other kind of farm. I'm not familiar with the specs for setting up a 504, but from your description that's far too much wear in a short period of time. Have you ever noticed heat or smell from the brakes?...this could indicate being set too tight. Good luck getting it sorted out. Mike in Exeter Ontario
