Order Farmall Cub Parts Online
Cub Carb Adjustment?
Ken
08-18-2001 09:53:43
Need help in adjusting the Farmal Cub carburetor. I just have one adjusting screw. What do I look for when adjusting and at what engine speed?
Thanks Much, Ken
Bus Driver
08-18-2001 17:26:15
 Re: Cub Carb Adjustment? in reply to Ken, 08-18-2001 09:53:43
The adjusting screw that points upward at an angle toward the rear of the tractor adjusts the fuel mixture at slow idling speed. On the side of the carburetor toward the engine, there is a screw on the throttle butterfly actuating lever that controls the speed of the slow idle. High speed mixture is not adjustable on the IH carburetor of the Cub. The high speed jet is the brass hex nut on the side of the carburetor near the bottom. Clean it with out damaging the polish of the holes in the jet.
