Farmall Touch-Control System
J-Philippe Bour
08-17-2001 19:15:17
I read in my operators manual that I can only use IH Touch-Control Fluid to refill my Fast Hitch system. Does anybody have an alternative kind of oil to suggest ? I read somewhere to use an non-detergent oil SAE-30.
Andy Martin
08-18-2001 19:29:31
 Re: Farmall Touch-Control System in reply to J-Philippe Bourget, 08-17-2001 19:15:17
Short answer: hydraulic fluid if Hy-Tran is not available.
30w non-detergent has been recommended on this board for Lift-All's, a different (and older)hydraulic unit.
Phil Auten (Tx)
08-17-2001 20:07:28
IH HyTran is what would be generically called tractor trans-hydraulic oil. It can be used in transmissions and hydraulic pumps/systems. It usually corresponds approximately to SAE20 non-detergent motor oil. Either one will work pretty much the same, but I prefer the trans-hydraulic oil personally. Price is about the same, but I figure the hydraulic oil is formulated to work in hydraulic systems where motor oil is primarily a libricant. If the hydraulic oil does not give satisfactory service in your system, try the SAE 30 non-detergent oil. Sometimes a worn pump will give good service with the SAE 30 when the lighter oil won't.
My 2¢,
Phil
Haas
08-17-2001 19:17:33
Use IH HyTran Fluid. Or an equivalent tractor fluid. Available at any farm supply store or at any dealer that sells tractors.
