Weight of SMTA?
Jeff
08-11-2001 15:15:53
I just got my Super M-TA running today, and I need to get it to the Buckley Old Engine Show. Do you know the weight of this tractor? It says about 9,000 lb in my book when it's fully loaded and ready for plowing, but I have air in the rear tires, and I only have one pair of the rear wheel weights (I think they're 145 lbs each). Thank you.
sammy the RED
08-12-2001 13:56:46
 Re: Weight of SMTA? in reply to Jeff, 08-11-2001 15:15:53
Dry weight for Super M-TA is 5456 lbs. w/narrow front, gas engine.
John Y
08-12-2001 13:31:51
The Super M weight is listed at 5100 pounds in the IH tractor data book. The MTA has a slightly larger rear frame and a longer clutch housing to accomodate the TA. Ad some weight for those differences and 2 x 145# for weights and should be close
Carp
08-11-2001 15:38:58
I would guess that it is between 5 and 6000 pounds with 1 set of wheel weights and no liquid in the tires. My M weighs 5400 lbs set up the same as yours, and the SMTA should weigh a little more.
