Raising tricycled front end?
RedTed/MO
08-10-2001 14:37:37
Farmall Super C with NF, both front tires shot, resting on rims. Nowhere to put a jack. Anybody got a trick for jacking up a tricycled front end so I can replace the tires and go? Thanks. RedTed/MO.
RedTed/MO
08-11-2001 07:43:27
 Re: Raising tricycled front end? in reply to RedTed/MO, 08-10-2001 14:37:37
Chocked the wheels and put my jack under the clutch housing;... worked fine! Thanks for your help. (I'll be back.) RedTed/MO
RedTed/MO
08-11-2001 07:41:25
Bob M
08-10-2001 16:30:29
Securely chock the rear wheels both ahead and in back of the tires. Now loosen (don't remove) the wheel mounting bolts. Finally stick a bottle jack under the clutch housing (set the jack on a block if req'd to get the height) and jack away. Both front wheels can now easily be removed!
TahtOtherGuy
08-10-2001 14:44:22
This is an old-fashioned trick. Put a cement block down with a slanted board infront of 1 TIRE ONLY. Drive the tractor onto the block. You can change the Other tire, and do the same for the oppisite tire.
RedTed/MO
08-10-2001 15:11:54
 Re: Re: Raising tricycled front end? in reply to TahtOtherGuy, 08-10-2001 14:44:22
Neglected to mention: tractor is loose, but not running. RedTed/MO
Haas
08-10-2001 19:07:52
 Re: Re: Re: Raising tricycled front end? in reply to RedTed/MO, 08-10-2001 15:11:54
Lock the brakes and chock the rear wheels so she can't move. Put a hydraulic bottle jack under the flat place on the bottom of the clutch housing and jack her up.
ThatOtherGuy
08-10-2001 18:54:23
You can still pull it up with your car, but there's probably easier ideas if it ain't running.
ThatOtherGuy
08-10-2001 18:52:20
