Re: identification
Jeff
08-03-2001 19:23:43
Kim,
If you look on the engine block on the oil filter side of the tractor you will see two flattened areas near the valve head and engine meet. There is one near the front of the engine and one near the back (above the oil filter). One of these should be stamped with a serial number. It may not be the same as the chassis number, because the engine may have been replaced.
Kim
08-05-2001 07:40:28
 Re: Re: identification in reply to Jeff, 08-03-2001 19:23:43
Thanks for the help I found the serial number just like you said I would and found out that it is a 1940
