F-14 Serial Number
Larry
08-02-2001 21:02:58
can anyone tell me if there is another way to find out the year of a f-14 other than the serial number plate on the gas tank support. This support has been replaced sometime in the past. Is there another number stamped somewhere or is there a way? Thanks, Larry
JDM
08-03-2001 17:14:35
 Re: F-14 Serial Number in reply to Larry , 08-02-2001 21:02:58
Just in front of the fuel pump is a flat surface with the numbers mentioned below
Bob Kerr
08-03-2001 08:09:32
The serial number pad for the engine should be on the left side of the engine toward the front. It is hand stamped on a rasied pad on the block. At least that is where it is on my F-12. I don't think an F-14 is that different as far as the number location goes. Hope this helps.
Bob Kerr
08-06-2001 09:17:39
 Re: Re: F-14 Serial Number in reply to Bob Kerr, 08-03-2001 08:09:32
I was at a show last weekend and looked over an F-14. the number is in a different place that my F-12. My F-12 has the number next to the fuel pump and the F-14 I looked at has the number on the fuel pump side of the engine but towards the back of the block in the middle. It is stamped on a raised pad.
Farmall43
08-02-2001 21:04:40
I believe you may be able to figure that out by the engine serial #. Others may be able to tell you more. Good luck
