Dip stick
dave welsch
08-01-2001 09:48:52
looking at a 1950 farmall "M" to buy. question!
this has a dipstick and not a petcock for
checking the oil is this normal? when did they
start having dipstick?
keith
08-02-2001 13:51:08
 Re: dip stick in reply to dave welsch, 08-01-2001 09:48:52
One comment I haven't seen yet is that all replacement service parts blocks were drilled with the hole for the dipstick. Possibly this unit has had the block reeplaced. At the dealership where I worked we regularly drilled a lot of them to install a dipstick.
JDM
08-02-2001 16:40:21
 Re: Re: dip stick in reply to keith, 08-02-2001 13:51:08
BUT,the hole wasnt always filled wit ha dipstick!Mine dont got one and its an IH repalement block.
MDJim
08-01-2001 19:31:40
both of my 1948 MD's came with dipsticks. The only petcock is on the injector pump. No petcocks on the oil pan. I tend to agree with Guy Fay, it was model by model thing.
Joel Williams
08-01-2001 16:42:31
My 52 Super M has dipstick and petcocks both. It also has a 281 cubic inch engine instead of the 264. Still can't figure that one out.
Denny Frisk
08-02-2001 10:49:29
 Re: Re: dip stick in reply to Joel Williams, 08-01-2001 16:42:31
You have a 450 engine block that had the dipstick. We had a 450 gas and It had the dipstick without the petcocks.
Guy Fay
08-01-2001 15:46:01
Kerosene-Distillate engines always had petcocks. Eventually, gasolene only tractors go the dipsticks. Don't know when dipsticks started, but its not a model by model thing.
Guy Fay
08-01-2001 15:44:44
Ace Schrunk
08-01-2001 14:37:47
If dipstick is in right side of block IH made a tool kit to drill the block so a dipstick could be added
Ace Schrunk
08-01-2001 14:37:29
Dan
08-01-2001 13:19:47
If this is a dipstick that screws into the hole where the top petcock went, it is probably an after market unit. I have one a SMTA and have seen the same things used on older JD tractors that used petcodls. The base is a square unit and the dipstick screws into it. personnally would as soon have the petcock I think
Danny
08-01-2001 09:53:59
Engine has probably been replaced with a power unit engine or engine from W-6. I believe both of these have dipsticks, but not certain on W-6.
Sven
08-01-2001 14:54:33
 Re: Re: dip stick in reply to Danny, 08-01-2001 09:53:59
W-6's have petcocks also, no dipstick.
dave welsch
08-01-2001 10:08:29
once again i'm new with farmalls, what is a
power unit engine or a w-6 and what year did it
come out?
Haas
08-01-2001 12:08:00
 Re: Re: Re: dip stick in reply to dave welsch, 08-01-2001 10:08:29
The W-6 is the "Standard" non-row crop version of the M. Wide front, low profile, used mostly in the west in small grain country. Power units are the engine/clutch only on a stand, used to power generators, sawmills, whatever. You can tell if it is a W-6 engine by finding the engine serial number. If the engine serial number starts with the letters WBKM, then the engine came from a W-6. If UBKM, then it was from a power unit. The M engines serial nos. started with the letters FBKM. On my MD, the engine serial number is on the LH side of the engine block about in the center. Not familiar with the gas engine so don't know exact location of the serial on it.
