Hydraulic
John
07-26-2001 22:32:58
Is it possible to put a hydraulic system on a Farmall A that did not originally come with it. If so, what is involved in doing this?
tiny
07-27-2001 18:19:24
 Re: Hydraulic in reply to John, 07-26-2001 22:32:58
if it is electric start you could use a elictric hydulic pump. i use one on my A to raise and lower a plow blade.
Haas
07-27-2001 05:59:18
Yes, possible. However, the A does not have the place on the block to mount the hydraulic pump like the one that is on the Super A. So, you have to use some other pump arrangement, such as a belt driven pump that drives from the fan belt arrangement somehow. It's probably just as easy and not much more expense to sell your A and find a Super A to replace it.
