406 engine swap
Randy
07-26-2001 05:23:47
I have recently purchased a 1960 406 tractor with what I believe to be a 221 c.i. 6 cylinder gas engine. The motor was bad when purchased and I'm looking for a replacement motor. I've been told that the engine in a IH 403 combine from approximately the same year is swappable with the 406 engine. Can anyone tell me if this is true? And if so, is there a particular 403 year or motor I should be looking for? Thanks in advance, Randy
Mike
07-26-2001 11:34:35
 Re: 406 engine swap in reply to Randy, 07-26-2001 05:23:47
You have to chang timing gear covers. But it will fit
MrG
07-26-2001 09:07:17
My 560 was born a diesel but has been repowered with 6 cyl gas engine from a 403 combine. I was told it was the same CID as the gas engine for the 560, the difference being that the tractor engine had sleeved cylinders and the combine engine was cast. In either case, the CID was more like 283 (not sure..CRS), but considerably larger than 221. Gadget
MrG
07-26-2001 09:07:14
the tractor vet
07-26-2001 08:12:56
First you must read and under stand you operators maniual and know your tractor , then engauge the brain before operation.
Randy
07-26-2001 10:59:57
 Re: Re: 406 engine swap in reply to the tractor vet, 07-26-2001 08:12:56
Gee... this helped me a bunch.
I posted that I was sorry for the typo, it was early and I was thinking about the combine model 403 - (406 vs 460). So I'm sorry to have wasted your time.
Denny Frisk
07-26-2001 05:46:42
I think You have a "460" tractor.
Randy
07-26-2001 06:47:00
 Re: Re: 406 engine swap in reply to Denny Frisk, 07-26-2001 05:46:42
I'm sorry, the tractor is an IH 460. To early in the morning and thinking to much about the 403 combine led to operator error.
