Ihc 504
stan
07-25-2001 10:30:08
I HAVE A 504 WITH REMOTE HYDRALIC HOOK-UP,WOULD LIKE TO KNOW SIZE OF HARROW IT WILL PULL. NEED SOMETHING FOR HARD GROUND,THANKS
Denny Frisk
07-25-2001 11:09:41
 Re: ihc 504 in reply to stan, 07-25-2001 10:30:08
By Harrow, I'll assume You mean Disc Harrow. There's many other kinds. With a 504 I would try to stay with something between 8 and 10 ft. The 504 is basically an over-grown H, same displacement but the engine block is similar to the C and Super C, 200/230/240 block with wet sleeves. The rear end is very similar to the H. It's a little too light for a 12 ft. disc, but it Would pull it. Hills, hardness of ground, amount of ground to cover, etc. would all be factors to consider. Peg tooth harrow is not much good for tillage, mostly a finishing tool. Spring Tooth harrow is used mostly for stirring up plowed ground prior to planting.
TP from central PA
07-25-2001 10:49:45
I never used a 504 but my friend's 560 has no problem handling a 12 foot #37 IH Disk Harrow. I don't think a 504 would have any trouble handling a disk of this size as I can pull the same disk with my SM-TA with little difficulty even thought I set it up to penetrate the ground deeply.
Good Luck
S-E Michigan Part Timer
07-25-2001 13:11:16
 Re: Re: ihc 504 in reply to TP from central PA, 07-25-2001 10:49:45
I agree with the disk suggestion. Dad has a 504 gas- Pulls a 10' disk ok in light ground, but will make it work in heavier ground. Won't quite do it in 3rd, but ok in 2nd. Also as stated, it's just an overgrown C.. but good hydraulics.
Ed
07-26-2001 18:42:16
 Re: Re: Re: ihc 504 in reply to S-E Michigan Part Timer, 07-25-2001 13:11:16
My dad had a 504. geared slightly higher than a Super M but couldn't pull as much. Great HYD system and live PTO. Some came with a 3 point.
Mowing, sprayer, cultivator, spreader, weeder - great. Plow, Disc, not so good will have trouble with an 8' disk in heavy soil.
