Sickle Bar
Zito
07-24-2001 20:54:01
I have this old IH sickle bar cutter and would like to find out what year it was made. It is a tow behind deal with a seat on one piece of steel with pedals and a handle that the operator would use. The Bar is run by the steel wheels.
Bill Smith
07-25-2001 21:36:13
 Re: Sickle Bar in reply to Zito, 07-24-2001 20:54:01
Sounds to me like you got an old mower there. May well even be a horse drawn set up. You might take a better look at the tongue as well. About all horse drawn machinery had a long tongue that would reach out in front of the horses. These tongues were subject to be altered in later years when farmers turned the horses lose and got on there first tractor. Alot of them cut there tongues off and made them shorter so the machinery would work better on the tractor. There was no need for the exceptionally long tongue then. I have never seen a real early mower for tractor but the mounted seat on implement is kind of a dead giveaway for horse drawn. You might look in the what I believe is the 100th anniversary International Harvester book. I looked through that book one time and it was quit detailed on all the equipment IHC made. I wish I could get my hands on one of these books again. If you could find one, it would probably be in there. I hope this helps.
Michael Soldan
07-25-2001 03:53:31
Zito, on the transmission casing and perhaps under dirt, grease etc there should be some information, ie. McCormick Deering No.6 ect You will be able to get as much info from that and that will help us establish the year . good luck from Mike in Exeter Ontario
