Farmall 140 hydrolics
PW
07-22-2001 20:15:39
I have a 1960 Farmall 140, and have problems with the hydrolic pump pumping hydrolic fluid back into the block. I have replaced the seal several times but it blows the seal out after only an hour or so of operation. I have had the shaft on the pump built-up recently but that hasn't helped.
IH dealer said there are 3 differant pumps that were put on the 140 but have tried all three differant seals with no remedy to the problem.
HELP!!!
Haas
07-23-2001 05:20:17
 Re: Farmall 140 hydrolics in reply to PW, 07-22-2001 20:15:39
There are some relief passages in the pump parts that allow the fluid to circulate from the seal area back to the low pressure side of the pump. If those are stopped up, you will blow seals no matter what you do.
