Re: 3pt. hitch
Medfarm
07-21-2001 20:30:28
The belly pump will only put out about 800 to 1000 PSI max which will govern what you are capable of lifting. As the previous post stated, if the front end comes off the ground, you are lifting too much. On one of my M's with good auxilary hydraulics and a stong 3-pt hitch which I built, I can lift a 9' Domeries tandem disc. The disc is capable of outpowering a modified M engine unless I pull in a low gear. If speed is an issue (which it usually is), I switch to a 80 HP tractor.
Tom
07-21-2001 21:51:42
 Re: Re: 3pt. hitch in reply to Medfarm, 07-21-2001 20:30:28
Basically I understand Tractors, What I am shooting for is people that have used this system and their opinion of it and I am wantig to feed big hay bales this year. I don't care if I need weights on the front or whatever. How much do you think it will lift like 800 lbs or 2000lbs? I don't want to buy it if it won't do what I need.
Mwedfarm
07-21-2001 22:41:13
 Re: Re: Re: 3pt. hitch in reply to Tom, 07-21-2001 21:51:42
Call Saginaw and ask them what their 2 cylinder 3 -point hitch is cabable of lifting with a specfic hydraulic pressure. Also the center of gravity of the large round bales from the pivot point of the hitch should be known when you talk to them along with the total weight of the bale. I have never lifted hay bales with a tractor but used my rough terrian forklift. A suggestion for adding front weights-built a frame which bolts onto the tractor frame and use suitcase weights. They are relatively cheap, easy to find and easy to remove when you do not need them.
