Farmall C transmission
jrih
03-15-2009 10:43:31
Wanted to know if anybody could tell me where to check the Transmission Fluid in a farmall C and what kind of fluid it will require. Thanks. Also, anybody know where to check the hyd. fluid on a 460?
burnsg2003
03-15-2009 18:55:16
 Re: Farmall C transmission in reply to jrih, 03-15-2009 10:43:31
A Farmall C takes 90 weight oil in the transmission
Erik Dekeyser
03-15-2009 12:28:43
On the right hand side of the tractor and on the hydrolic box there is a plug near the top, just remove it. If you havent ever changed it maybe you should just dump it out and clean the filter and put in new hytran oil it will work a lot better and it doesnt take a lot of oil.
SDE
03-15-2009 17:45:07
 Re: Farmall C transmission in reply to Erik Dekeyser, 03-15-2009 12:28:43
Erik,which tractor are you referring to? A "C" takes 80/90 weight.
STEVE
ScottyHOMEy
03-15-2009 18:37:11
 Re: Farmall C transmission in reply to SDE, 03-15-2009 17:45:07
If I'm reading right, Erik is describing the Touch Control, and you're thinking of the tranny.
Erik Dekeyser
03-16-2009 04:57:51
 Re: Farmall C transmission in reply to ScottyHOMEy, 03-15-2009 18:37:11
Yeh sorry guys i was thinking of the touch control instead of the tranmission. Must of been sleeping when i was on LOL.
CNKS
03-15-2009 11:33:19
460 has a plug on the left side of the differential housing, about halfway up. Use Hytran as 90W will cause problems with the hydraulics and TA. Use 90W, etc in your C rear end, Hytran in the hydraulics.
thumbanger
03-15-2009 10:49:32
Walk to back of tractor look on the right side of tractor you will see a small plug take it out. It will be full when gear oil runs out. I use 90 wt.
