Re: F-12 Where to start the restore process?
Michael Soldan
07-15-2001 09:47:20
The first thing I want to do with a tractor is get it running correctly. Everyone has different tolerances for what that means. I don't mind a little blue smoke when it starts , I don't want oil burning when it operates. I will decide on rings etc. Then I go over the tractor for leaks after it is running to suit me.I replace seals and repair things that need repair. I add things that are missing such as PTO cover ,a light or a fender or a battery box, anything that needs replaced I would check tires next and then preping and painting would come last after the tractor is complete and running. To me a tractor is no good unless I can get on it and start it and put it to work,so getting it to run right is the most important and starting point for restoration..my 2 cents! Good luck from Mike in exeter Ontario
