How do you check a starter?
JW(NC)
07-12-2001 18:19:08
I tried to start my 140 just as it started rolling backwards and the starter started spinning. Did I break a shear pin or something? I took the starter off and turned the motor with a crowbar. I hooked the starter to the battery and it will spin. Put it back on the tractor and all it will do is spin. I doesn't engage the flywheel. Does anybody have any suggestions? Thanks in advance!
JW(NC)
07-13-2001 18:30:44
 Re: How do you check a starter? in reply to JW(NC), 07-12-2001 18:19:08
Found the problem.....broken bendix spring. Replaced it & starter right up!
Thanks for your help.
Haas
07-13-2001 05:14:42
Take the starter to a starter rebuild shop. Probably one somewhere in your area. They can likely fix it for you.
gene b
07-12-2001 20:45:22
might have ruined the bendix
