Help needed on charging troubles
joe
07-06-2001 16:39:50
generator wont polarize. runs on neg 10 or so. when ya touch wires to polarize it jumps all the way over to 20 then back to 10 on the neg side. generator and reg. were just checked yesterday and they are fine. is my amp gauge screwed up?? i am lost at this point. this is an M. origianlly battery was hooked up in reverse. everything has been checked since. fires right up, all wires appear fine.
Lloyd
07-07-2001 05:56:07
 Re: help needed on charging troubles in reply to joe, 07-06-2001 16:39:50
One way to tell if your charging system is working is to measure the voltage on your battery with everything off, then start it up and measure it again. If the system is charging, the voltage at the battery should be higher with the engine running.
The Red
07-07-2001 01:14:08
I noted in your other post you mentioned that you "turned the key" and it started. Do you have a starter solenoid rigged in the system?????
On the amp gauge, note the needle position when everything is off. They don't always center at zero. Turn the ignition on without starting the engine and note the position. If it is showing a 3 or 4 amp positive indication, then you need to reverse the wires on the amp gauge.
With the amp gauge face laying down, if it is positive ground, the line from the battery goes on the left post. The line from the bat. post on the regulator, along with the line to the coil switch and lights go on the right post.
Just the opposite for negative ground.
Rocky Allen
07-06-2001 19:25:03
Hey Joe. One thing you might want to remember is that the M is a positive ground system. Try putting your battery back in like it was originally and repolarize and see what happens. Hope this helps. Rocky
