Engine Sleeves
Author |
Roger
02-24-1999 17:28:22
I am restoring a Farmall MD and am finally starting the reassembly process. The sleeves I took out of the engine stuck out about .040" above the block which according to the manual is correct (one even stuck up .050". The new sleeves I bought from Case IH only stick up a few thousands of an inch above the top of the block. I just finished restoring a Super C and the sleeves stuck up too far and the head gasket leaked. Does anyone know why the sleeves are supposed to stick up above the block. Is it to seal the high pressure of the cylinders? Engines without sleeves have a smooth transition at the top of the cylinders. I don't see how the head gasket can compensate for .040" step at the cylinder. It seems like all the manuals I have for Farmall tractors have a different number from near nothing on the M gas to .040" on the MD. However, will these sleeves that don't stick up above the block cause me problems on the MD. I would appreciate any information. Roger
Roger
02-27-1999 07:58:10
Re: Engine Sleeves in reply to Roger, 02-24-1999 17:28:22
Yesterday I talked to the service manager at the local Case IH dealer about the sleeves and how much they should stick up. He says that the sleeve only needs to stick up enough so that you can catch your fingernail on the edge (probably only a few thousandths). The .040" must have had something to do with the old gaskets they used. Roger
Farmall Gray
02-25-1999 16:23:03
I don't know about the MD, but on the later tractors they make shims to adjust the depth of the sleeves. Check with your dealer on this. I'm sure there is a reason why they are supposed to stick up above the block, but I can't tell you what it is. I would say that if it says so in the manual, then that's the way it should be.
Brian Miller
02-25-1999 11:33:24
I am also rebuilding the engine in my H. It too was stuck, but the sleeves were flush with the top of the block. The new sleeves that I got are also flush with the block. I wouold not worry about the new sleeves, maybe the old ones were not in right, or somehow loosened up. It sounds like someone has been in the engine before, if the old sleeves were .040 over. So don't worry if the new sleeves don't "stick up" a little. I am not sure if this will help, but I would not be worried about
Brian Miller
02-25-1999 11:22:03
Clinton E. Hofstetter
02-25-1999 11:17:47
My son is also working on restoring a Farmall MD and we have also noticed that there are special specifications for the MD. It was an early design diesel that started without a pony engine. We would be interested in hearing how your progress is coming and your results on the head and head gasket. My son has had to replace the block, put in new sleeves, new pistons, rings, bearings, etc. Expensive!
jack
02-25-1999 13:42:53
Re: Re: Engine Sleeves in reply to Clinton E. Hofstetter, 02-25-1999 11:17:47
expensive but look at what you are going to have when you are done
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
