Re: Farmall Super A Hydraulics Touch-Control System
Vern
06-30-2001 22:18:14
Disconnect the control rod from the handle and see which end is stuck. If it is the handle then you will just have to work it loose. If it is the lower unit then you have a big problem.
Sharon
07-01-2001 13:39:37
 Re: Re: Farmall Super A Hydraulics Touch-Control System in reply to Vern, 06-30-2001 22:18:14
I've had the levers disconnected and the problem is on the Touch-Control unit. What do I have there,, 2 separate small cylinders? Are they independent of each other internally ? If I pull the unit , what will I find is the probable culprit and what type of maintenance can I do to it besides o-rings? possible that the cylinder rod is gummed up, as the lever is in the forward position? I have the parts manual and owners manual ordered, tractor came with a preventive maintenance manual covering Cub, 140,240, 340 series. Touch control for cub and 140 looks like what I've got but it really doesn't address the problem. Thanks for the help.
