Re: need advise on my new tractor
big fred
06-29-2001 21:15:32
I think the C has the same type of coolant drain pipe that the A and B have, a short section of pipe extending down from the lower hose fitting on the block. It should have a pipe cap on it that you remove to drain the system. When you refill, make sure you have the coolant pre-mixed before adding it as you don't have a pump to mix it after it is in. The antifreeze and water have different densities and if not premixed the thermosiphon will not work and your engine will overheat. Enjoy your C!
