Re: Mowing hay that has been knocked down by rain.
Dan
06-28-2001 20:32:20
I would also tip the sickle points down as much as you can without plugging. That down wet grass is tough to cut and plugs easily. As the others have said, if you can cut it the opposite way it is pushed over it will work better but you will miss some any way you do it
