Charging woes
Author |
joe
06-23-2001 12:06:28
have an m. had generator, and v. regulator rebiult a few months back. replaced push button with key switch and got new battery. went out today and battery is dead. amp meter shows positive when key is turned on and it shows positve while running. this is the 3 or 4 range no higher. running neg ground.(is this wrong) it was that way during repairs of above mentioned parts. how can i tell if its pos. ground. should it not stay 0 when the key is turned on??
gene b
06-23-2001 20:10:56
Re: charging woes in reply to joe, 06-23-2001 12:06:28
hoof up positive ground as that is the way it is supposed to be your reg will not work as the reverse current coil is set for positive ground polarize the gen by touching bat ttterm to arm term just to draw a spark that is enough if it wont charge then ground the field if it still wont charge the gen is bad you have probably ruined the reg by using neg ground but you might have beenlucky
The Red
06-23-2001 12:22:51
Joe I will bet the generator was rebuilt as original positive ground. Reverse the cables on your battery and see if it will then charge. If you go to negative ground, which you can, then you have to reverse the wires on the ampmeter and repolarize the generator. That positive charge indication you were seeing was actually a negative charge.
joe
06-23-2001 18:09:43
Re: Re: charging woes in reply to The Red, 06-23-2001 12:22:51
thanks red. appreciate it. hows rusty h coming?
The Red
06-24-2001 03:51:36
Re: Re: Re: charging woes in reply to joe, 06-23-2001 18:09:43
No progress to report Joe.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1967 Ford 3000
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
