Re: Hauling
Kendall
06-18-2001 11:32:41
Check your owners manual for towing capabilities. I was thinking about doing the same with a Ford Ranger 3.0. After checking the owners manual I discovered that the weight of the trailer alone was the towing limit! If your ZR2 has the 4.3L then you might be able to do what you want a couple of times a year.
SE_Michigan Part Timer
06-18-2001 14:04:25
 Re: Re: Hauling in reply to Kendall, 06-18-2001 11:32:41
As long as the trailer will hold it, you should be fine. Just take your time and drive 1/4 mile in front of you. Plan ahead especially if you don't have brakes on the trailer. Just be sure not to use overdrive if you have the automatic! I've pulled 5000+ lbs many times with an S-10 or jimmy w/ a 2.8l at low speeds (below 45 mph) and back roads.
