Air Cleaner Oil Weight
Larry Z
06-18-2001 04:58:53
What is the correct oil weight to put in a super M air cleaner? How many gallons go in the transmission/gear case?
gorilla
06-18-2001 22:20:10
 Re: Air Cleaner Oil Weight in reply to Larry Z, 06-18-2001 04:58:53
13 Gallons !! If you go to change it make sure you have plenty "O" buckets!
John
06-18-2001 22:02:23
Oil bath air cleaner oil weights: SAE 30, Above +80 degrees F: SAE20, +80 to +32 degrees F: SAE 10WBelow +32 degrees F.
john d
06-18-2001 06:15:28
Air cleaner gets SAE 30. Doesn't matter if it's detergent or non-detergent. Fill to the line on the side of the cup.
Transmission will take somewhere in the neighborhood of 6-8 gallons of oil. There is a plug to check the level on the left side below the clutch linkage. There are two drain plugs, one below the pto on the back, and one at the front of the transmission section. If the tractor's spent time in the rain, you probably should also drain the belt-pulley assembly if it has one.
The Red
06-18-2001 06:21:18
 Re: Re: Air Cleaner Oil Weight in reply to john d, 06-18-2001 06:15:28
6 gallons of 90 weight on the H. 13 gallons on the M/Super M.
