Super M problems??
Binder-Man
06-16-2001 11:44:30
We own a 1952 Super M runs great, but when it gets up to operating temperature it over flows through the over flow pipe,I talked to another fellow who has a Super M that does the same thing, are we looking at water pump troubles or somthing else?? Thanks for any help!!
Binder-Man
06-17-2001 18:30:53
 Re: Super M problems?? in reply to Binder-Man, 06-16-2001 11:44:30
Thanks red for your help on this problem, this super M belongs to my son-in law,I've been busy baling hay and we have a tractor show this weekend, nothing like waiting until the last minute on this one. The radiator cap Bob M said was part of the problem and being over full another,we've been so darn busy to look at it, but again you fine people came to our rescue!!!
Binder-Man
06-17-2001 12:50:27
Hey Red-BobM-Jakee- thanks for the info we need to get a new temperature gauge to tell for sure where we are at for sure on temp-what is the correct pressure rating for the cap?? Happy Fathers Day to ALL!!!!
The Red
06-17-2001 13:39:49
 Re: Re: Super M problems?? in reply to Binder-Man, 06-17-2001 12:50:27
Ken Updike has IH gauges built to spec. 608-455-2411. I believe the pressure should be around 8 psi. You can get a thermostat from NAPA. I don't have the M parts number in front of me.
Bob M
06-16-2001 14:40:06
Hey Binder-Man - Assuming the motor's not overheating, installing a new radiator cap (one with the correct pressure rating) should solve your problem.
The Red. OOPS!
06-17-2001 05:11:13
 Re: Re: Super M problems?? in reply to Bob M, 06-16-2001 14:40:06
Bob I just took a wire brush to the serial and stamp date numbers. 9-16-R which makes it a 1948. The engine serial number is 300050 which also corresponds with a late 1948.
The Red
06-16-2001 12:11:28
What is your temperature gauge indicating when it starts to overflow?
jakee
06-16-2001 19:22:01
 Re: Re: Super M problems?? in reply to The Red, 06-16-2001 12:11:28
most of the time wen you have a cracked head they push water out the cap,Mac-tool man has a block tester that will show if there is corbunmooxied in the water-there like 15.00 bucks,also make sure you are not filling the radiator to mutch,good luck
