Company Logo Shop Now
Re: Ether M
The Red
06-15-2001 09:03:57
Dick you could have restrictions in a couple of areas. First of all, open up the high speed mixture another 1/2 turn and see if that helps. If not, I would do the following.
Remove the fuel bowl strainer and the screen. Turn on the gas and see if you have good flow. If not, the inlet on the strainer is plugged. You will more than likely have to remove it and clean out the tank.
If you have good flow, reassemble and unhook the line at the carburetor and check for fuel flow. It it is good, then remove the nut/strainer assembly that the fuel line hooks to. That strainer might be plugged.
If it looks good, take the carburetor bowl off and remove the float, needle and seat and blow compressed air into that chamber where the seat screws in. You might have some blockage there.
Let us know if any of this helps or not.
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an ... [Read Article]
Latest Ad: John Deere 116W wire tie baler in working condition comes with side hitch and chute TEXT if interested [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
