Sounds to me like the fuel tank is dirty or the line from the tank to the filters or somthing between the primary and final filters is partialy plugged. I suspect this because it took the filters so long to fill while you were bleeding the system. Was the tractor sitting before you cut hay today? If so it sounds like the fuel in the filters burned off after the first five rounds, and the fuel coming from the tank couldn't get there fast enough due to the plugged lines, and the system airlocked.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
