SUPER M SERIAL NO.
BUCK
02-21-1999 14:41:03
A friend has found a super M for sale and sent me the serial no. of 356980 PL with a 3 under the PL and 8-264 under the 3. I know the 264 is the cu. in. ... and if the serial is 35698, leaving
the {o} off the tractor would b a 1953 model...the 0 befor PL seems to be too long a number for a super M. Can anyone help me with these numbers. Thanks. Buck
K-Mo
02-23-1999 18:24:28
 Re: SUPER M SERIAL NO. in reply to BUCK, 02-21-1999 14:41:03
Buck,
I think you might be looking at the Block Casting Number.
The numbers you give are confusing. The 8-264 is probably 'C-264'. Could your 356980PL acutally be 356980R1?
The tractor serial number is on an ID Plate on the left side of the Clutch Housing. On a standard Super M, the serial number will look something like-- SM12345
Kent
