Throwout bearing farmall 300
dewy
11-17-2023 15:54:54
How do you remove throw out bearing from carrier on the ta..what holds it in ,an how do you install back in carrier,again what keeps it in carrier...also same question for main clutch throw out bearing...thanksdewy
BarnyardEngineering
11-18-2023 12:14:33
 Re: Throwout bearing farmall 300 in reply to dewy, 11-17-2023 15:54:54
The throwout bearing is a thrust bearing so pressing directly on it won't hurt it like a normal ball bearing where you have to be careful to press on the inner race only if trying to install it on a shaft, or on the outer race only if trying to install it in a bore.
D Slater
11-18-2023 05:47:49
On main clutch bearing if going to replace it just use blocks on two sides under outer bearing and use something to drive middle of cast piece down. T/A one has two holes in back of cast holder. Block up on two sides of fork and angle blocks so you can put a spacer between spring loops and block so holder doesn't rock. Use a pin punch that will just pass through small holes. Moderate tap in one hole and then other one until it drops out. 3 to 4 taps most times. Just use something that works to drive them back on.
D Slater
11-17-2023 17:13:27
Split behind engine. Remove linkage from main and t/a clutch operating shaft. Remove two bolts in main clutch fork and slide operating shaft out. Remove release bearing and bearing carrier. Has 3 bolts. Remove clutch shaft. With top covers off center housing remove t/a clutch operating shaft retaining ring and washer on right side, Remove set screw from t/a operating shaft fork. slide shaft to left side until you see one key, remove it. Next move to left until second key is seen. after first key is out shaft can turn out of line with keyway on left so turn to line up if needed. Lift t/a clutch release bearing and fork out. Should be able to see what it needs from there. maybe I misunderstood question. Both bearings are a press on carrier or holder. This post was edited by D Slater on 11/17/2023 at 05:18 pm.
dewy
11-17-2023 18:17:25
 Re: Throwout bearing farmall 300 in reply to D Slater, 11-17-2023 17:13:27
Sorry slater i already split the tracter got ta out..i was just talking about the throw out bearing...press off .thats what i wanted to know...how it was on an off...so what do you use a press..it wont hurt it pressing on...i never seen the back of a throw out bearing...dewy
dewy
11-18-2023 21:12:32
 Re: Throwout bearing farmall 300 in reply to dewy, 11-17-2023 18:17:25
thamks yall..... dewy
