Order Farmall Cub Parts Online
48 Cub still not starting
Rayman66
11-15-2023 17:29:38
I am still unable to get 48 Cub to start. This is what I have done: New points, gapped at .013; new condenser; New coil; New spark plug wires.
Plugs gapped at .025.
Made sure on top dead center before reinstalling J4 magneto.
When cranking, motor will back fire at least once out of muffler.
"Sounds" like it wants to start (you know what I mean).
Pulled plug after cranking motor over and not a hint of gas on the spark plug.
Any additional help will be greatly appreciated.
Thank you in advance.
Keith-OR
11-17-2023 13:51:51
 Re: 48 Cub still not starting in reply to Rayman66, 11-15-2023 17:29:38
I read your first post, you said it was back firing out both exhaust and intake. You were given lots of good suggestion on fixes.
So now you have did most everything you were suggested to do, and still can't get the tractor to run. No gas on plugs, back fires out the exhaust, tires to run, hhhmmm. sounds like no or very little compression, possibly couple of valves could be stuck open..
No compression, you will have no vacuum to pull fuel up into cylinders. DO a compression test, if you don't own a compression gauge you can borrow one from either Auto zone or Oriely's auto parts.
Keith
teddy52food
11-16-2023 05:43:35
Switch all the plug wires across from where they are now in the cap & try again
grandpa Love
11-16-2023 05:21:24
Welcome to call anytime. 256-404-
zero123. Happy to help, sure sounds like a timing issue.
gene bender
11-16-2023 04:20:27
backfire means spark isnt in time with compression does the rotor line up with the tower when it fires try the old condensor new can be bad and clean the points remove #1 plug with wire attached and plug grounded now turn the sw on put your finger in the hole have someone hit the starter you should see spark at the plug when engine hits compression stroke thats the easiest way to see if #1 you do have fire and #2 is the spark in time with the engine
Charlie M
11-16-2023 04:39:10
 Re: 48 Cub still not starting in reply to gene bender, 11-16-2023 04:20:27
I'm thinking if the plug is grounded to the tractor and your finger is in a spark plug hole you are going to find out real quick if the plug fired. I did something similar once with a mag sitting on the platform of my H, I turned it by hand and when it fired my leg was against the drawbar. I'm not doing that again.
the tractor vet
11-15-2023 23:06:17
welp if it is a dist ing and not a Mag the POINTS set at .020 not .013 that is the points setting on a mag.
rustred
11-15-2023 22:41:31
There is 2 TDCs. U need to be on the compression stroke not exhaust stroke. Thats your problem as I said last time. And you did not verify that you were on compression. Glad ur not charging by the hr. Lol
old
11-15-2023 20:58:19
Have you made sure you have a good blue/white spark at each plug that will jump a 1/4 inch gap or more?? A back fire to me say the timing is off or you have a couple plug wires crossed
used red MN
11-15-2023 20:39:19
You checked for the correct TDC as I explained in your other post? Every time the piston comes to the top of the cylinder is NOT always the compression stroke of that cylinder. It is all explained in my reply in your other post, see link. Also did you check to see if all cylinders pushed at least some compression against your thumb when cranking. If it does than that eliminates stuck valves. A guy on here used to post under the handle of ..not just air.. take heed.
