Super A main bearings
Daniel
05-27-2001 10:31:03
Hi. Does anyone know if the crank and rod bearings in a Super A can be replaced without spliting the tractor? The IT manual says they can be changed from the oil pan but it also says the bottom half of the rear main seal retainer has to come off. Can you get to this with the flywheel on? Thanks for any comments. Daniel.
Tyler (MD)
05-27-2001 17:06:21
 Re: Super A main bearings in reply to Daniel, 05-27-2001 10:31:03
David,
Here's a couple of pics from my clutch repair.
third party image
third party image
third party image
third party image
You may be able to get at the bolts that hold the retainer to the block but I'd wonder if you could get to the 2 bolts that hold the halves together.
Hope the pics help.
Tyman
Sorry Daniel...I called you David. :-) Another Pic
05-27-2001 17:10:56
 Re: Re: Super A main bearings in reply to Tyler (MD), 05-27-2001 17:06:21
Pic of the crank with oil pan off:
third party image
Tyman
