400 won't start
Steve
05-27-2001 08:28:40
After further checking, I've found that I have weak spark at the plugs. When I crank it some times I get fuel running out the intake of the carb. Any ideas.
Charlie
05-27-2001 10:45:36
 Re: 400 won't start in reply to Steve, 05-27-2001 08:28:40
I've noticed on all my Farmalls if I crank them much without starting I get some gas out the bottom drain. I'd take care of the weak spark problem and then see what happens. I'd suggest putting in D21 spark plugs or equivalent - will give you a good spark if the rest of the ignition system is in good shape.
The Red
05-27-2001 09:08:30
Steve my starting technique on Hs and Ms with a cold engine is to crank with full choke about 3 turns, then crank with no choke. Sounds like you are flooding.
Does the 400 have a 12 volt coil or a 6 volt with a resistor in the line? I am not familiar.
Steve
05-27-2001 11:14:24
 Re: Re: 400 won't start in reply to The Red, 05-27-2001 09:08:30
It has a 12 volt coil and a resistor in line.
The Red. That's The Problem
05-27-2001 11:28:54
 Re: Re: Re: 400 won't start in reply to Steve, 05-27-2001 11:14:24
I second Red Dave's comments. Remove that resistor out of the line and see how she starts.
Red Dave
05-27-2001 11:23:52
May be some trouble right there. 12 volt coil should not need a resistor as it would tend to halve primary coil current thereby reducing voltage developed by the secondary (High Voltage) side of the coil.
