Working on a Farmall Cub abused by a past owner. Went to install new pto shaft and found the end of the transmission shaft was mushroomed out so the pto coupler wouldn't slide onto it.
I removed the transmission shaft out the front per the shop manual. This is a model that has a washer on each side of the rear bearing. I had to drive the shaft forward since in was damaged and will need to get new washers.
My question is I see no type of snap ring or grove where one would go to retain the rear bearing and nothing listed in the parts book.
Thank you,
Gary
Thank you,
Gary
